RCU Forums - View Single Post - How many bottles of CA do you use when building a kit??
Old 12-07-2003 | 05:09 PM
FlyingPilgrim's Avatar
FlyingPilgrim
My Feedback: (26)
Default RE: How many bottles of CA do you use when building a kit??
I found a neat trick for applying epoxy when you wish you had it in a squirt bottle:
Mix the epoxy as usual, then scrape it into a regular sandwich bag. Don't worry about trying to get it neatly into one corner, just scrape it in. Then lay the bag on your work bench and sqeeze it into one corner. Twist the bag up to seal all the epoxy into one corner, and hold it by the twisted end. Cut a TINY hole in the corner with your X-acto, and squeeze it out like a baker's frosting applicator. It's a good way of applying just the right amount instead of gooping it on with popsickle sticks.
Pilgrim
