RE: Digital Servos
jetsetter Quote "As a matter of fact, some digital servo's with long leads don't like 6v and will jitter terribly. Don't answer question if you don't really have the true answer"
Well I DO know what I am talking about and I also run several digital servo's mixed with standard servo's on 6v. with NO troubles. These are also being run in race planes with high demands on the whole system. I run 1400 and 1500 mah batteries with great results. Sounds like the jitters are something that only you are having troubles with. Maybe you should be careful who you insult!!![>:]
Kaos1- It is a good idea to up the mah rating of your batteries along with the qty of digitals you run. No you don't have to run 6v but it does increase the torque of the servo.
