RCU Forums - View Single Post - Hinges?
Thread: Hinges?
Old 12-07-2003 | 09:30 PM
Sportflier
Default RE: Hinges?
The round Robarts hinges are very easy to install as all you need to do is drill a hole to suit the hinge. Just be sure the pivots are aligned before the glue sets.
I thought I'd like demountable control surfaces so I'm using heavy duty Dubro hinges with cotter pins.
Making the slots is a pain, but what I found helps is to drill a series of small holes with the drill press at the proposed hinge location (into the edge) ... makes it easier to dig out the wood.
