RCU Forums - View Single Post - Kange Laser 2000
Old 12-07-2003 | 11:47 PM
  #70
water_born
Default Mounting Zenoah G62
I'm trying to use a Zenoah G62 on the Kangke Laser 2000. Because the carburetor is side mounted on this engine, it will be protruding outside of the cowl on the right side. I'm having trouble figuring out how to cut the cowl to be able to install it. It looks like a slot will have to be cut in the cowl more than 1/2 its length in order to clear the carburetor?? Can the carb be mounted closer to the engine so that it clears the cowl?
Advice from anyone using this plane/engine combination would be appreciated. A photo of the G62 is shown below.
[img][/img]
