Hi Erik
The life expectancy on the glow plug should be quite long. It's difficult to give an actual "time" or "cycles" because the glow plug is only used during the start sequence and spends most of it's time off.
For replacement plugs, we recommend using McCoy #9s. We have found these to be the most consistent and durable plugs to use.
Sincerely,
Ed
ORIGINAL: Erik R
Kevin or Ed,
What kind of life can I expect from the glow plug in my 2300? Also,what type should I use for a replacement?Thank you.
Erik
