RCU Forums - View Single Post - Kioritz 23.6cc vs. Homey 25cc
Old 12-08-2003 | 11:30 AM
Volfy's Avatar
Volfy
My Feedback: (23)
Default RE: Kioritz 23.6cc vs. Homey 25cc
ORIGINAL: mikenlapaz
Retapped the short end 5/16-24, (what is the actual thread on Echo? Do not have any metric pitch gauges and it sure looked SAE, surprize, but it will work)
It's either 8M1.0 or 8M1.25, I don't remember which. 8mm is very close to 5/16", enough that props I reamed using either 8mm or 5/16" reamers will work interchangeably. If the thread pitch looks to be very close to 5/16-24, then for sure it's 8M1.0 since 1 inch = 25.4mm.
5/16-24 = 24 threads per inch
8M1.0 =~ 25 threads per inch
8M1.25 = ~ 20 threads per inch
Ralph, I found that the G-23 doesn't like to be propped down too much. I got not much higher higher RPM as you did with an MA 16x8, and was kinda disappointed. Swapped in a 16x6 APC, and the little Zenoah came alive. I'm even think about changing to a 15x8 and really let her rip. Plus the GP Spacewalker it's on flies kinda slow with the 16x6 anyway, so pitching up a little should help speed it up. I would love to get a G-26 to play with, but right now I've got enough of these little Echos already.
