RCU Forums - View Single Post - Wild Hare Edge 540t set-up plans
Old 12-08-2003 | 02:29 PM
  #32
Jonathan Ott
My Feedback: (25)
Default RE: Wild Hare Edge 540t set-up plans
The DA 50-R is rear intake, the carb will stick through a hole in the firewall back into the fuselage. Check out the downloadable instruction manual and you can see that Tom simply set up some rails in the fuse for the throttle and choke servos. should be a simple setup for a rear intake engine, and for side mounted carbs, there is accomodation on the engine box for a servo form what I can make out in the pics.
Jon
P.S. I got a note from Tom, he would have shipped my Albino Edge out, but he has not come across the white ones yet. May have been packed first (finished last) and in the other end of the container. Guess I have to wait a bit longer.
