RE: aircraft downloads-problem
Flying Rubbernutz,
Can you hum a few more bars? Are you getting any errors when you try to load a plane, or do they just not show up? I have 84 files of airplanes that normally come as self-extracting executibles if you want to give any a try. Just make sure that your application path is either the DEFAULT or ensure the path to your aircraft folder is right. Can you see the .pln and .eng files you extracted in your "planes" folder?
Let me know and I will see how else I can help. I also have over 190 trim schemes.
