RE: Ziroli Corsair for G2??
ezflyr,
G2 Add-On Vol 1 has the Corsair. If you have the full version of G2 you can copy the original plane and modify the parameters to suit the physics and size of your Ziroli. There is also a relatively large number of engine types you can apply. You will have to get your plans out and measure everything up, but the end result should be satisfactory. I have "tweaked" out the CAP and later the 540 to represent my 33% Laser 200's with some success.
Hope this helps.
