RCU Forums - View Single Post - Yellow Starfire
Old 12-09-2003 | 03:27 AM
Shaun Evans's Avatar
Shaun Evans
Default RE: Yellow Starfire
Hi,
Yeah, there really isn't anything you need you can't get from Yellow or from your LHS. There are turbine inlets available as well as conformal fuel cells with 68 oz capacity. That with a 12-oz header is plenty for P-80ish power. They run just as well without a bypass as with. You don't need anything special at all, other than a tailpipe, also available from Yellow. If you have any questions, gimme a call. Hope this helps.
