RE: Homelite 25cc -> 30cc
I havent had a homie yet that had the clutch so I cant help there. To remove the crank I take off the backplate and all the innerds, lay it so the shaft is pointing up and with the nut screwed on a few threads, lay a peice of wood over the nut and wack it with a hammer. To replace it I insert it into the bearings, place a deapwell socket behind the crank and a socket WITH a washer to protect the bearing in the front and put it in a vise and crank till it seats. Crude? yep but it works. Piper
