RE: Uproar 60
i didn;t it's a kit a friend makes it's a fiberglass fuse foam core wing and you cut all the wood parts the kit is 125 dollars and worth it it has plug in wings on a tube
the wing is 80 or 82 and it's about 70 inches long weight 8 pounds dry if you want a big uproar . i will give you his number he could tell you what size he blew it up i think like 90% they are a big plane.
