RE: launching a combat plane
HI CKOK! If you were able to get the plane to fly on a hand launch that nearly missed the ground, then that means to me that your plane is either too heavy or under powered or both. Trying to make your plane lighter is usually the best solution. You might try setting your ailerons so they are slightly down in the neutral position, but not so much that it creates other problems when you get up to speed. GOOD LUCK!
