RE: Kit advice
I think you would get bored with the Fazer or SomethinExtra with that 32. You'd be better off going to the 46 class motors. The 32 would pull the plane, but not many wild stunts. The profiles might be a good transition since they rarely tip stall as long as you have someone get you up and trims the plane first before you take over. At mid throttle, they are easy to make corrections by not being too crazy on surface movement.
