RE: Twin Elevator issue - pull pull
If you have the dual servos set up equally and the throws match on the ground, then chances are that it's merely snapping out on you in flight when too much elevator input is applied. That's common for many SA planes. Unless you're doing some 3D, keep the elevator travel low. You may go through a lot of work changing the setup to a pull-pull and end up with the same results.
