RE: Twin Elevator issue - pull pull
Gyri,
I did a pull-pull set up for my Cap-232 elevator without problem. The slight difference in the line lengths do not cause a differential (none that i can see, no problems in flight) as long as your servo is centered.
However, Stickjammer has a very valid point, better to check on your throws than to rebuild unnecessarily.
