RCU Forums - View Single Post - Breaking In Engine
Old 12-09-2003 | 10:38 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Breaking In Engine
Blowing out white smoke means the engine is slightly rich. If you are blowing out fuel, the engine is very rich. But the smoke is also somewhat affected by atmospheric conditions.
For break-in, you want to run the engine slightly rich. To do this, start it up, run it wide open, and turn the needle valve in slowly. You will hear the engine peak (Max RPM) then start to die as you continue to close the needle. Now, you are too lean. Back the needle out slowly, the engine will return to peak. Keep opening the needle until you hear a fair decrease in RPM, but not so much that fuel is blowing out of the muffler.
That's the setting you want to use for break-in.
