RCU Forums - View Single Post - 1/4 scale or Gang standard servos?
Old 12-10-2003 | 03:02 AM
Patriot's Avatar
Patriot
Default 1/4 scale or Gang standard servos?
Just thought I would start a little post here concerning an issue I have beating around in my head for a couple days now. I am building an 80" bipe around 18-20lbs, and am considering one of two optins for tail surface servos. Do I just go ahead and use the 1/4 scale servos, or is it better to gang up two standard servos with pulleys for a bit of redundancy?
I saw an airplane in a nearby thread that uses a nice pulley setup. It ocurred to me that if he loses on of the two operating servos on the ruuder for example, the other will still operate the rudder, but only with half travel, not great, but enough to get the plane on the ground.
Just wondering whether or not this is really a good idea, or would it be best to just stick with the 1/4 scale servos? I have to admit, I do like the double servo idea, but like the simplicty of using one good 1/4 scale servo even better.
Patriot
