Changing Module on 9C
Could you confirm that it is perfectly OK to change the freq module on my 9C (change channel) without causing any problems.
Also, in another post you told someone they could not plug the battery into the DSC slot on their R149DP Rx. I have had mine that way (inadvertently) for some time now and it has worked perfectly. What is wrong with putting the battery in the DSC slot. Thank you.
