RE: Engine Tuning
If the engine is an ABC then you should run it "just right." Neither lean nor rich. If it's ringed, then a little on the rich side. Just point the aircraft straight up and lean it to peak rpm then back it off a couple clicks. That's about as perfect of a setting as there is.
