RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 12-10-2003 | 11:16 PM
  #701
santi's Avatar
santi
My Feedback: (32)
Default RE: U-Can-Do 3d 46?
Has anybody out there lateraly balanced there ucd? As i posted in the ARF section. which way is better, placing the string on the crank shaft or placing a screw on the center top of the firewall then loop the string. Im running a saito 91 in mine and already have a few dozens of flights already. When I try balancing it on the Shaft the left wing drops. but when i use the screw method. It balances perfect. Anybody else with the same set up lateraly balance theres yet? If so, did you have to add weight to the wing tips? Oh. If there is another way to balance the plane i would love to know about it.
Santi
