4 CYCLE VENTS
You can try to run a larger tube from vent nipple. You may have to use a connector to do this. But run the vent tube to a 2 oz tank that will collect the oil. Make sure the tank has a vent also. Keep all vent lines short as possible. Hope this helps John
