ORIGINAL: JimTrainor
The one plane I have with a PCM receiver is setup to idle the engine, and give full rudder/elevator/aileron deflection. As such, it will slow down quickly and spin to the ground in very short order. Hopefully out of harms way. It also lowers the gear - so that it will be abundantly clear what happened.
No disrespect intended... but man would I like to be there the day that happens ... ;-)
gus
