I fly the Patriot with a Jett-50 and it hooks along pretty well
The biggest concern I would have with your proposed set-up is how nose-heavy you will be... That is a looong nose so a little more weight on the nose needs ALOT of weight in the tail-[X(]
Dar is SUPER knowledgeable about all the weight/rpm/prop. stuff- Seems like my Rossi-65 with full-pipe would haul ***** on a Patriot but no idea compared to the Jett-50... Takes some thinking and planning with the firewall/engine compartment-
Remember an OS-91VRDF will turn a 10x10 pretty well if you are serious about speed!
