RCU Forums - View Single Post - How do I repair a cracked fg cowl?
Old 12-12-2003 | 07:43 AM
Zpat's Avatar
Zpat
Default RE: How do I repair a cracked fg cowl?
The proper way to repair fibreglass is to add a fibreglass backing to the inside of the cowl under each crack and after it has cured remove the crack with abrasives down to the backing.
Then make the proper amount of lay ups to replace the fibreglass that has been removed.
Proper technique doesn't require any bondo.
