RE: Best brushless/brush motors for 3D Flying
well -you just got moto calced-
Note the 3 amp difference?
In actual practice - on a thrust stand -reading actual thrust - not some WAG-- you will find that the increased thrust- in that thrust range (over 20 ozs on a small motor), comes at the cost of sizeable increases in input from the motor -which is output from the battery -
In the world of thrust -and props etc-- the prop output changes require a lot more power in - for a little more thrust output.
But your choice of motor is fine- just don't have a heart attack when you compare the calculated with the actual.
