RE: Change battery how often? Checked under load?
The modern NiCd can be good for up to 12 years of use. (that is an exceptionally good pack with excelent maintenance...) Average will be closer to 4 years service.
To maximize battery life, you need to ensure the pack is discharged and recharged at least monthly. This means that the people who don't fly for 6 months each year need to cycle the batteries durring the non-flying season. A NiCd which is not cycled for 6 months will often go bad.
If you have a cycler and can test the capacity of a battery when its new.. write the tested value and date on the pack with permanent marker. If a cycle test shows it has lost 15% of capacity don't trust the battery. There's about 2 charges difference between 15% loss and 30% loss... then another charge or two and its dead.
edit... added
How many flights on a charge? :::: What plane? What engine? What type of flying are you doing?
You can get over 2 1/2 hours of flying of a 2 meter glider using a 500 maH pack if not doing much aerobatics. You can get about 45 min of average .40 size trainer flying from a 600 maH pack. Under adverse conditions, you can get as little as 7 min flying out of a 1200 maH pack flying a 1.20 powered Pattern Competiton aircraft. Depending on how I fly it, my .90 powered Fokker Dr1 can get from 10 min to 90 min per charge from the 700 mah pack in it.
You REALLY need to have a meter to test the pack at the field and see if its safe to take off for the second flight, no matter what you fly.
