RCU Forums - View Single Post - Laterly balancing your plane.
Old 12-12-2003 | 07:53 PM
Stick Jammer
Default RE: Laterly balancing your plane.
JoeAirPort,
Take a look at any plane with obvious right engine thrust. Chances are that the center of the engine mount is off to the left side of the firewall. How far to the left depends on the amount of right thrust. When correctly set up, the front of the prop hub should be on the airplane's centerline.
