RCU Forums - View Single Post - vibrating servo
Old 12-13-2003 | 12:09 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: vibrating servo
Can you describe the type of linkages at the servo arm and aileron, and the type of pushrod used ? Servos don't normally vibrate when you return to neutral, although there might be some deadband. I suspect you have some freeplay in your linkage system and that can cause flutter. Did you overdrill the holes in the servo arm and control horn ? Is your pushrod stiff enough ?
