RCU Forums - View Single Post - Toothbrush technique for removing excess glue from CA hinges
Old 12-13-2003 | 04:08 PM
Jerryfwiw
Default RE: Toothbrush technique for removing excess glue from CA hinges
I say do whatever works for you. I really like the crayon on the hinge line trick. I'll have to try that.
No good. The CA hinge is layered and the CA will flow under the wax. It will keep it off the surface though.
