RCU Forums - View Single Post - Engine Moutning position
Old 12-13-2003 | 10:30 PM
CafeenMan
Default RE: Engine Moutning position
on the side view of the plan, look at where the tank is located. Draw a centerline through the tank. The centerline of the engine carburetor should be 1/4" higher than that. But the thrust line doesn't change, so you rotate the engine to get that position.
