RCU Forums - View Single Post - Using 9C sliders to change top end rotor pitch on heli
Old 12-14-2003 | 04:59 PM
taildraggerdave
Default Using 9C sliders to change top end rotor pitch on heli
Hello,
I was told the 9Z has a factory installed mix that allows you to vary the high end pitch of the heli rotor blades. Will the 9C allow you to program a mix into it that lets you do the same thing?? I want to be able to use the right hand slider to allow me to change my top end blade pitch one degree on either side of 9 degrees.
