RE: Twin Elevator issue - pull pull
Hi,
Thanks for the info on battery and engine. I'm going to use a Rossi .45 and will try the battery under the tank. Without a pitts muff, I had to mount he engine rotated 135 degrees clockwise with muffler on pilots left. This puts the carb niple very low; also, the fuse slot likits tank placement. Right now, engine floods easily, so may change everything. Bob
