Originally posted by nrgy
Will the FA-50 work fine with this plane? And lastly, what servos do you recommend I use? I'm thinking of possibly using JR 531s all around except for the retract servo. I guess another way of putting it is, in general, what torque is usually recommended for the different controls for a 40-50 size aircraft?
The Saito might be a little weak for your model. 40 sized planes should have between a 60-70 sized 4 stroke to pull them effectively, your 50 will fly it, but you probably will need to fly it on it's wings, since the motor won't be able to pull ya outta sticky situations.
