RE: GP <span class=
Serge, no flying wires ? What is your Eagles final weight ?
Pettit, where is your CG set ? How are the supplied flying wires holding up ? Are you using the supplied wheels ? Any problems here ? I had to you use the supplied ones since no other would fit inside the wheel pants. That might be OK, since I do not have any problems with the supplied ones on my Pitts either. I guess they are the same wheels.
