RCU Forums - View Single Post - Touching
Thread: Touching
Old 05-16-2002 | 02:51 AM
Emissions
Default Touching
I can now say that I am able to go into a stable hover consistently, I am trying to bring the plane down a little bit but I can seem to hold her and she usually tips off to one side. I start my approach low to the ground at idle then shoot in bursts off throttle until im upright in the hover usually im about 20 feet off the ground or so, maybe lower on some occasions. Like I sad I cant seem to lower her down (The only time I do try to lower the plane down is when im a lot higher than 20 feet since im not too consitent with doing it) What should I keep in mind when i am trying to lower the plane down and touch. Should I start my approach lower and close to stall speeds so that when I start my hover I am 7-10 feet off the ground?
