Touching
Ditto, the reason for using little bursts of power is to restore control. When you lower the throtle, you have less air moving past the tail, so control starts to fade on you. You are entering a whole new level of chalange to the whole 3D thing. Hope to get there myself one day! if you in the mood to modify your plane to make it easyer, a bigger elevator and rudder may help a bit.
