RE: Best method of "pinning" firewall or wing block through the fuse sides?
Hey Ernie:
You can still put in the triangle stock. Just use some big stuff like 1/2". Trim down the point of the triangle that goes against the fillet until it will fit flush. Then epoxie it in place. Should do the trick for you.
Mark Shuman
