RCU Forums - View Single Post - SIG LT-40 QUESTION
Old 12-16-2003 | 01:44 PM
ballgunner 's Avatar
ballgunner
Default RE: SIG LT-40 QUESTION
The biggest problem you will have with a bowed wing is keeping the ailerons straight. If bent they will not hinge properly and probably bind when moved. Greenriver RC has your answer. The LT40 ARF that I patched together had a bent aileron. Much trouble with binding.
