Solder or Epoxy?
I have tried several different ways to solder-and I also still get a weak joint-bought a wire feed welder-which is very small wire gauge and has no gas bottle-the flux is in the wire-since the flux is only to remove the air around what you are tacking-but it works very well-I do not have joints breaking loose any longer or countless hours of trying to produce several small assemblies-any pitting I get -I use jb weld as almost a bondo and sand smooth and finish-looks nice and holds-thanks
