RCU Forums - View Single Post - What is WASHIN on a Wing use for
Old 12-18-2003 | 03:08 PM
SST
Default RE: What is WASHIN on a Wing use for
WASHIN is when the trailing edge of the wingtip twists downward , and is useful for rekitting your plane by causing it to snap at low airspeeds, such as on approach, by allowing the tips to stall before the root...WASHOUT is when the tip twists up, which causes the tip to stall later than the root, hopefully causing a gentler, straight-ahead (and hopefully recoverable) stall.
