RE: carb problem
Hmmm, that is a puzzle. Your gas/oil mix should be OK. Make sure that there is no problem with the little crankcase pressure pulse passage to the carb. Watch for sealant or a gasket out of place blocking the passage, yet be sure the passage is sealed from leakage to the carb bore or outside.
