RE: Will U Can Do 3D .46 Harrier?
they harrier good you just got to get it figured out . i fly both and the 46 i think is a little better at water falls . but it won't do a ke wall as good still pushing the cg back . the blenders a little on the boreing side but it dos it with its on style flat spins good . really it dos every thing some are just slower than a other plane . check the fus good flex it a little snaped my frist one on a ke pop up . it had little glue on wing bolt plate to . it just had bad wood the new one is soundy built . don't have a dig camera try to buy one when i get back from buying more planes for my present's . were is the 120 size u can do 3d i seen one fly that blowed my mind MORE it had a 84 inch wing was 88 long had a mds 148 on it.
