RCU Forums - View Single Post - Zen G23LH Modify ???
Old 12-19-2003 | 10:11 AM
av8tor1977's Avatar
av8tor1977
Default RE: Zen G23LH Modify ???
WHOOPS...
Also look to see that there is a passage for the crankcase pulse pressure on both sides of the crankcase!! It will be a little hole, or notch, that lines up with a little hole in the cylinder that goes up to the carb mounting pad.
AV8TOR
