RCU Forums - View Single Post - problem with futuba 6exa
Old 12-19-2003 | 10:34 AM
Krysta
Default RE: problem with futuba 6exa
Hi Joe123s,
We don't recommend that you use metallic tweezers to remove your battery. You should be able to remove this by simply pulling straight out on the battery wire.
In this case, I believe the radio should be sent in to be checked, the tweezers may have shorted something out inside and it is better to be safe than sorry.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (http://www.futaba-rc.com)
