ORIGINAL: supereri
Hello everyone,
First time poster here. I am thinking about buying the UCD 60. I am open to suggestions on engines. I am serioulsy considering the Saito 100. Cost is a pretty important consideration for me. I know the Saito isn't the cheapest route. I definately want four stroke, unless there is a very compelling reason not to.
This will be my second plane. I have heard that if you dial down the throws it will be a good first aerobatic plane.
I am also REALLY open to suggestions on the transmitter. I am currently considering the Futaba 6exa, mainly for its cost ($179.99). But I am not tied to this.
Also a suggestion on what reasonable priced servos for whatever radio you suggest.
About the only thing I am sure of is the desire for a U Can Do 60, everything is is up in the air.
Thanks in advance.
Eric
Phoenix, Az
welcome to the forums Eric.
Here is my setup and I find it to work good for me:
Saito 100
Futaba 9202 all around except a Hitec 5645mg on the rudder
Radio is the old Futaba 6da soon to be replaced by the 9C this january
good luck with your setup
matt
