RCU Forums - View Single Post - trim for takeoff
Old 12-19-2003 | 06:08 PM
nilo's Avatar
nilo
Default RE: trim for takeoff
If the plane just don't go straight when on the ground, that's probably because the front wheel gear in not positioned correctly, aligned to the rudder. If you have a tail wheel direct connect to the rudder, also check its alighment when the rudder is straigh.
That's what I would look at first.
Nilo
