RCU Forums - View Single Post - Zen G23LH Modify ???
Old 12-20-2003 | 12:02 AM
mikenlapaz
Default RE: Zen G23LH Modify ???
Dave,
If I put it back together it will be short the fins down to the outer magnet surface and 4 starter lugs, as they got the cutoff wheel on the drillpress this afternoon. Yes it has the spindle drive to wheel surface. Have not pulled the fork apart, there is play, suspect the bearings are shot, bike shop may have those. I'll put it on a back burner and do some more checking for wheels and rims. Put together it may fetch enough to be worth the additional investment. Not sure I would ride it much here, too many potholes. ( A few years ago local JC's had a float in major parade depicting a VW stuck in a pothole with only half the car visiable. People laughed but government was not embarressed enough to retictify the problem)
Been trying to figure out why the low power output. I can only visualize the type/size of transfer ports; duration of time the intake and exhaust are open; and the compression (squish area at TDC) Maybe someone can enlighten us on the other factors.
