RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 12-20-2003 | 11:13 PM
  #716
joebob's Avatar
joebob
My Feedback: (14)
Default RE: U-Can-Do 3d 46?
By bad wing, are you talking about the crushed ribs? I found the rib where the servo mounts in one side was broken in mine, but I was bale to pop the pieces back in place and I saturated the rib with thin CA. No problems so far. (At least with the wing - see post 714!)
I'm still trying to get mine dialed in. I had the rudder on pull pull with the servo mounted at the rear of the wing opening. I needed about 2 oz of tail weight to get it to fly level inverted, so I decided to move the rudder servo back to the original position in the tail. Hopefully get to try it out next week...
