RE: Setup with DA50
RCTom,
How is the vertical? Can you aim straight up, stop and punch it and have the plane climb out? If it does how would you explain the climb out? What type of batterys are you using? Do you have anymore pics of the setup? I got a CF landing gear that I had purchased for my cap that I plan on using, getting a CF tail wheel from graphtech, and might get the CF tube from Troy built. Then just trying to decide if I should use my NiMH or go with duralites or powerflights. Just want a nice light setup.
Brian
